Старый 15.12.2007, 01:11   #1
axStart: Mass update on table properties
Источник: http://axstart.spaces.live.com/Blog/...C0A0!204.entry
We all have run in trouble in the past when for a lot of tables the same update needs to be done:
Below script can help you out. It will look in all tables that are in the database (SQLDictionary)
Next it will find the related AOT Tree node.
static void ChangeTableProperties(Args _args)
    SQLDictionary   dictionary;
    TreeNode        treeNode;
    str             properties;
    while select dictionary
    where dictionary.fieldId == 0 &&  dictionary.name like("Proj*")
        treeNode     = TreeNode::findNode('\\data dictionary\\tables\\'+dictionary.name);
        if (treeNode)
            properties = treeNode.AOTgetProperties();
            properties = setProperty(properties, 'CreatedDate', 'Yes');
            properties = setProperty(properties, 'CreatedTime', 'Yes');
            properties = setProperty(properties, 'CreatedBy', 'Yes');
            treeNode.AOTsetProperties(properties);
            treeNode.AOTsave();
axStart: Check if the table field is mapped. Blog bot DAX Blogs 0 07.03.2009 00:05
axStart: table & field ID conflicts Blog bot DAX Blogs 0 29.05.2008 17:05
gatesasbait: Table caching and record delete()/update()/next Blog bot DAX Blogs 3 24.04.2008 22:55
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
Harish Mohanbabu: Table set / get properties Blog bot DAX Blogs 2 17.04.2007 15:28
Часовой пояс GMT +3, время: 16:54.
