Старый 21.08.2007, 10:40   #1
dynamicsusers: Making NAV use a certain index on SQL Server
Источник: http://dynamicsuser.net/blogs/waldo/...ql-server.aspx
This is going to be an article about "Index Hinting". I'm ashamed that I did not know about this feature until for a few weeks ago. Why? Because it has been in the bible for a long time (fyi, "the bible" is "The Application Designer's Guid" aka the w1w1adg.pdf on the \doc folder on your CD). How long? I've seen it in the ADG of 3.10 … so it's been there for a long long time. Just see Chapter 30.6. Hynek Muhlbacher brought this to our attention when Mark...(read more)
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
dynamicsusers: SQL Server: x64 vs x86 Blog bot DAX Blogs 0 28.06.2007 17:00
dynamicsusers: NAV SQL Indexes Blog bot DAX Blogs 0 23.05.2007 23:40
dynamicsusers: NAV SQL Tuning - Covering Indexes Blog bot DAX Blogs 0 27.04.2007 17:10
aEremenko: Диагностика проблем при установке Microsoft Dynamics Ax 4.0 на Microsoft SQL Server 2005 Blog bot DAX Blogs 0 28.10.2006 16:01
Часовой пояс GMT +3, время: 02:16.
