Старый 04.07.2007, 11:40   #1
dynamicsusers: The Style Sheet Tool for Microsoft Dynamics NAV
Источник: http://dynamicsuser.net/blogs/kine/a...ew-object.aspx
Microsoft has released the tool fro creating Word Stylesheets for Microsoft Dynamics NAV 5.0. You can download it from PartnerSource here (or from this site here ). It includes one FOB file with new objects, which are used to define the stylesheets, and documentation. The process of creating styleheet is very easy: you create new card for the styleheet, where in header you define the base table and in lines you define all used tables, fields you want to export and relations between tables (e.g. Sales...(read more)
Старый 04.07.2007, 12:56   #2
IGG is offline
IGG
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Старый 05.07.2007, 05:51   #3
dynamicsusers: Microsoft Dynamics NAV Stylesheet Tool
Источник: http://dynamicsuser.net/blogs/gaspod...heet-tool.aspx
When Dynamics NAV 5.0 launched with the send to application feature, one of the main criticisms was that you needed to be a programmer to create new stylesheets.
I tried to solve the problem using some knowledge of WordML in a series of 4 blog posts on send to application but I really came up short.
Mark Brummel said in his blog post on at TechEd 2007 that Microsoft announced a graphical tool for creating stylesheets would be released.
Today on the Microsoft Dynamics Partner Newsfeed there was a link to the Microsoft Dynamics NAV Stylesheet Tool (partnersource login required.)
It looks like this is the first release of a tool - as it is not the graphical tool that was promised - but I have yet to check it out. Here is a quote from the page:
"To simplify this process, a style sheet tool has been created that does not require programming knowledge. The first version of this tool will support the export of data to Word, and this means that the only skill required to create additional style sheets is some end-user knowledge of Word.
The Microsoft Dynamics NAV Stylesheet Tool supports integration to Microsoft Word 2003 and Microsoft Word 2007.
It consists of a fob file and a user guide."
dynamicsusers: Dynamics NAV 5.1 at Convergence 2007 - Review and Comment Blog bot DAX Blogs 0 09.08.2007 16:50
dynamicsusers: Dynamics NAV on Vista Blog bot DAX Blogs 0 28.05.2007 14:51
Часовой пояс GMT +3, время: 15:36.
