Старый 12.04.2007, 16:10   #1
axaptabuilder: How to make Dynamics AX interface more user friendly with Tabax?
Источник: http://axaptabuilder.blogspot.com/20...face-more.html
Does it sound familiar for you when you work with Axapta you get heaped with different windows after some time? Maksim Belugin has developed a great tool called Tabax to help organize all your opened windows into tabs, quickly change their positions and so on. Tool and more information about it can be found on the front page of www.axaptapedia.com.
I have just started to use this tool and I think its really great and can make life much easier for Axapta developers. Tabax designed for Axapta 3.0 and, as author says, tested with Axapta 3.0 SP4. I have tried to use it with Axapta 4.0 and found that with just a few small modifications you can run it on Microsoft Dynamics AX 4.0 as well.
Here they are, my changes to Tabax version 0.2.4 to make it work with Dynamics AX 4.0:
1. Open method Pathes and comment out this string:
//["\Data Dictionary\Feature Keys\", #imageFeatureKey],
since there are no any feature keys in Axapta 4.0. Also add one more string
["\Data Dictionary\Perspectives\", #imagePerspective], // added
2.Open unpack method and modify it like it shown here:
if((conlen(packedMenuUsageStatistics) > 4)) { // added
menuUsageStatistics=Map::create(packedMenuUsageStatistics);
if(!menuUsageStatistics)
menuUsageStatistics=new Map(Types::String, Types::Container);
} // added
I haven't got enough time to test it with Axapta 4.0, so it might have more issues, but at least it works with these modifications in place. Hopefully Maksim will make a full test of it with Dynamics AX 4.0 and present us with a new version of his great tool in the nearest future.
November princess: Dynamics AX user friendly features Blog bot DAX Blogs 0 23.01.2008 16:30
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
axaptabuilder: How to make Dynamics AX interface more user friendly with Tabax? Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 12:41.
