Старый 28.10.2006, 16:40   #1
Dynamics AX: Returning the Current SQL Server, Database, and Configuration
Источник: http://dynamics-ax.blogspot.com/2006...-database.html
Recently I needed to add business logic around code, that acted differently based on what Ax instance I was in. I wanted to know the best way to always determine that, and after doing some searching I cam across the following line of code:
SqlSystem::databaseBackendDesc();
The above line of code will return in string value the: [Server Name] [Database Name]
This is not documented really anywhere, and the SqlSystem class is not something that can even be seen from the AOT itself. It's one of those hidden, but very useful classes that we have all had to deal with, or wish we knew more about. Anyway, this method works great and returns the correct information everytime!
Another method that is great comes from the xInfo class, and it looks like this:
xInfo::configuration();
This method will return the name of the current configuration in use, which in turn can also help you determine which instance of Ax you are using.
I know that I will have use for this in the future and so I have posted this little tidbit in hopes that it will helps others as well!
Find a job at: www.DynamicsAXJobs.com
Arijit Basu: Integrating MOSS 2007 and Dynamics AX Part I - setting up your development environment Blog bot DAX Blogs 1 14.01.2008 11:40
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
axaptabuilder: Notes about my experience in setup of Microsoft Dynamics AX 4.0 integrated with Microsoft Visual Source Safe. Blog bot DAX Blogs 0 27.06.2007 09:30
axaptabuilder: Notes about my experience in setup of Microsoft Dynamics AX 4.0 integrated with Microsoft Visual Source Safe. Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 12:41.
