Старый 25.03.2004, 14:44   #7
Bukovka is offline
Bukovka
Исправленный вариант, но все равно не рабочий ....
Table1: Field1, Field3
Table2: Field1, Field2
Table3: Field2, Field4
Table4:Field2, Field3, Field4
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tableNum(Table1), _formControl);
Query q = new Query();
QueryBuildDataSource beds
QueryBuildRange qbr;
qbds = q.addDataSource(tableNum(Table1));
qbds = qbds.addDataSource(tablenum(Table2));
qbds.addLink(fieldNum(Table2,Field1),fieldNum(Table1, Field1));
qbds.joinMode(JoinMode::InnerJoin);
qbds = qbds.addDataSource(tablenum(Table3));
qbds.addLink(fieldNum(Table3,Field2),fieldNum(Table2, Field2));
qbds = qbds.addDataSource(tablenum(Table4));
qbds.addLink(fieldNum(Table4,Field2), fieldNum(Table3, Field2));
qbds.addLink(fieldNum(Table4,Field4),fieldNum(Table3, Field4));
qbds.addLink(fieldNum(Table4, Field3), fieldNum(Table1, Field3));
qbds.joinMode(JoinMode::NoExistsJoin);
qbr = qbds.addRange(fieldNum(Field3, Field4));
qbr.value(‘06’);
sysTableLookup.parmQuery(q);
sysTableLookup.performFormLookup();
Dynamics AX: QueryRun and Query Objects - Binding operation failed to allocate buffer space Blog bot DAX Blogs 0 03.04.2009 08:05
Проблема с составлением Query axaLearner DAX: Программирование 10 01.12.2005 15:00
Как правильно построить Query Bukovka DAX: Программирование 0 25.03.2004 11:55
Часовой пояс GMT +3, время: 12:37.
