Старый 18.12.2008, 16:17   #1
Ириска is offline
Ириска
Аватар для Ириска
22 / 11 (1) +
Прислали логи. Там две ошибки, в основном, повторяются
Error: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Error Message: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Source File: Not available
Line Number: Not available
Request URL: http://crm.mediachase.com:5555/MSCRM...rmService.asmx
Stack Trace Info: [SqlException: An error has occurred while establishing a connection to the server. When connecting to SQL Server 2005, this failure may be caused by the fact that under the default settings SQL Server does not allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)]
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
и вот такая:
System.Net.WebException: The request failed with HTTP status 400: Bad Request.
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at CrmDiagTool4.CrmDeploymentSdk.CrmDeploymentService.Execute(DeploymentServiceRequest Request)
at CrmDiagTool4.Sdk.RetrieveOrganizationsProperties(CrmService crmsvc, CrmDeploymentService crmdeploysvc, CrmAuthenticationToken token)
at CrmDiagTool4.Sdk.get_AllOrganizationDictionnary()
at CrmDiagTool4.Form1.WriteSDKAllOrganizationInfo(StreamWriter sw)
И в чем тут именно проблема?
Старый 18.12.2008, 17:54   #2
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Сообщение от Ириска Посмотреть сообщение
и вот такая:
Настройте SQL сервер, чтобы он поддерживал TCP/IP протокол, похоже, что на данный момент поддерживается только Named Pipes.
Старый 19.12.2008, 19:11   #3
Ириска is offline
Ириска
Аватар для Ириска
22 / 11 (1) +
Мне сказали, что sql настроен для TCP/IP протоколов.
А может быть, к примеру, что это из-за разных версий протоколов? К примеру, если на сервере 6-ая версия стоит?
Старый 03.02.2009, 15:49   #4
Evgenia_f is offline
Evgenia_f
Здравствуйте!
У меня очередная проблема с бизнес-процессами. Остановилась служба Microsoft CRM Asynchronous Processing Service и запускаться не желает. Пишет "Служба Microsoft CRM Asynchronous Processing Service на "Локальный компьютер" была запущена, а затем остановлена.". В логах пишет что-то для меня непонятное:
Host CRM40: failed while starting monitoring asynchronous operations queue. Exception: System.InvalidOperationException: The requested Performance Counter is not a custom counter, it has to be initialized as ReadOnly.
at System.Diagnostics.PerformanceCounter.Initialize()
at System.Diagnostics.PerformanceCounter..ctor(String categoryName, String counterName, String instanceName, Boolean readOnly)
at Microsoft.Crm.Asynchronous.PerformanceCounters..ctor(String instanceName)
at Microsoft.Crm.Asynchronous.AsyncService.OnStart(String[] args)
Подскажите, пожалуйста, может, кто сталкивался, как побороть эту ошибку.
Старый 19.12.2008, 15:34   #5
Likefire is offline
Likefire
Заноза в заднице
Аватар для Likefire
547 / 50 (3) ++++
Записей в блоге: 1
Может винды какие-нить обновления приняли и сервис стал как-нить косо-криво работать - одному богу известно сие.
Старый 03.02.2009, 16:11   #6
Жесть какая-то... Евгения, я бы на вашем месте уже начал верить в карму... Служба сама остановилась, или ей помогали хотфиксами, выключением сервера кнопкой или пр. форс мажором?
Старый 03.02.2009, 16:36   #7
Evgenia_f
Еще чуть-чуть и начну верить! Серверу вообще ничем не помогали, работал себе и работал. Разве что новую организацию создала, но это тут ни при чем вроде... После перезагрузки служба повела себя так же. Repair попробовать сделать? Больше ничего в голову не приходит.
Старый 03.02.2009, 17:18   #8
Evgenia_f
Repair помог Спасибо!
Старый 03.02.2009, 19:11   #9
Likefire is offline
Likefire
Заноза в заднице
Аватар для Likefire
547 / 50 (3) ++++
Записей в блоге: 1
Скажите на милость,- а где вы эту самую службу "Microsoft CRM Asynchronous Processing Service" наблюдаете? Я почему-то в службах на несущем сервере не вижу её, хоть тресни...
Старый 03.02.2009, 20:26   #10
В службах, собственно, и наблюдаем. В оснастке "Службы на сервере" раздела "Администрирование" в панели Пуск. В учебных материалах утверждается, что на CRM сервере должно разворачиваться 3 службы:
Microsoft CRM Bulk E-mail Service
Microsoft CRM Deletion Service
Последние 2 являются дефектом обновления учебных материалов версии 3.0 и в новой версии отсутствуют. Их ф-ции ныне выполняет единая служба Asynchronous Processing Service. Документ IG так же придерживается этой версии.
За это сообщение автора поблагодарили: Likefire (1).
Старый 05.02.2009, 10:30   #11
Roman08 is offline
Roman08
Записей в блоге: 1
CRM 4: Waiting workflows
Под таким заголовком на сайте PatrickVerbeeten.com описано, как простым способом получить сообщение об ошибке - почему именно воркфлоу зависает в режиме ожидания, там же есть ссылка на сайт майкрософта , где опубликованы коды ошибок. По меньшей мере, это дает хоть какую-то информацию .
За это сообщение автора поблагодарили: Ириска (1), slivka_83 (1).
Часовой пояс GMT +3, время: 12:12.
