Старый 09.04.2022, 03:36   #1
alirazazaidi: How to configure 10.0.24 onebox VM on Local Laptop
Источник: https://www.tech.alirazazaidi.com/ho...-local-laptop/
Most of the time, I usually run Dynamics 365 Finance and Operations vm on my personal Laptop for R&D purposes.
But after downloading latest 10.0.24 vm from LCS. I am unable to run , admin User Provisioning tool. I got following error.
The value’s length for key ‘password’ exceeds it’s limit of ‘128’.
Later on LinkedIn Microsoft Employee Volker Deuss shared a link which helps me resolve this issue. Here are my notes.
Now Microsoft requires you to create one web application register in Azure portal.
And before your provide your user as provision as admin, you have to perform one more step.
Generate Self-Signed Certificates and here we use this application id. It configure some certificates.
And interestingly your own azure portal without tenant is not work. You have to create web application. in your tenant azure subscription. It will not work like my personal email. even I purchase azure subscription on my personal Id alirazazaidi@live.com And web application register there is not work.
So here are some steps to create register application in following steps.
open your azure subscription. and type in search box on top register app
Click on new registration.
Enter the name
Enter local Dynamics url. We used this link inside the Vm.
Also select web in first drop down. Here we need to create a web
Enter name and in
add one more redirect.
Click on Redirect URIs and add one more.
Save it a
Now copy the application id created and go to Dynamics vm
and now go to Dynamics VM. and right click on Generate Self Signed Certificates.
Next step Press N. and let it process , it will restart the services, Batch job. When this job is completed. You can register same domain id as admin Provision
And my id is become successful admin
And successful, run Ax 10.0.24 on my local laptop.
emeadaxsupport: Dynamics AX 2012 Reporting: How to configure order positions to be kept on one page Blog bot DAX Blogs 0 25.03.2015 01:13
dynamicscpm: How to Configure Microsoft SharePoint with Management Reporter 2012 Blog bot DAX Blogs 0 23.07.2012 21:12
Часовой пояс GMT +3, время: 23:01.
