Старый 07.08.2018, 19:11   #1
d365technext: Label Extension D365FO
Источник: http://d365technext.blogspot.com/201...on-d365fo.html
As We All know Label Extension is not available in D365FO with the same way we use to create form, Table and class Extension...
You can check the below screenshot Label extension option are gray/disable in menu.
What is the resolution?
There is way to create extension of Existing label files.
Add new label file like below image... In my demo I am Creating Extension of Sys Label file.
In Extension use Prefix of Existing Label File name then Add _Extension as Postfix
In my case file name was Sys_Extension. Now click on Add button and complete the wizard.
Select the Language is in use by Parent Label file and click on next ...
You can create new Label and override the existing one, For Demo purpose I have created Two Label @SYS456 which is New Label and the second I created @SYS12 which is already Exists in SYS Label File... We Created this one to override the existing Label.
Now I have create a menu Item and assign the @SYS456 Label to Menu Items...
To handle Override case, I have created class for the verification...
class SLD_DemoClass
public static void main(Args _args)
info(SysLabel::labelId2String2(literalstr('@SYS12'), 'en-US'));
info(SysLabel::labelId2String2(literalstr('@SYS456'), 'en-US'));
d365technext: FormHasMethod extension in D365FO Blog bot DAX Blogs 0 03.08.2018 18:11
d365technext: Card Pattern in Grid D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 11:11
d365technext: Private, Protected and Public attribute access in Class Extension Blog bot DAX Blogs 0 30.07.2018 20:13
stoneridgesoftware: Learn to Use a Label Creator Add-in Extension in Dynamics 365 for Finance & Operations Blog bot DAX Blogs 0 04.04.2018 01:13
emeadaxsupport: How label flushing works under the hood Blog bot DAX Blogs 0 17.08.2010 16:05
Часовой пояс GMT +3, время: 18:42.
