Старый 30.05.2013, 13:11   #1
sashanazarov: Generate a project with application objects from "used by" cross-references
Источник: http://sashanazarov.blogspot.com/201...eferences.html
Sometimes one needs to investigate where some field or method is used in the AOT. There may be a long list of AOT paths in the "Used by" form, and having a project with all those application elements may be a good starting point.
Add a button to xRefReferencesUsedByTypedTree form, set its Text property to "Create project" and MultiSelect to Yes:
Override its clicked method and use the following code:
void clicked()
    #TreeNodeSysNodeType
    XrefPaths xRefPathsLocal;
    Set treeNodeLocalPaths;
    SetEnumerator treeNodeLocalPathEnumerator;
    SysProjectFilterRunBase     project;
    UtilElements                utilElements;
    ProjectNode                 projectNode;
    Dialog                      dialog;
    DialogField                 dialogField;
    super();
    treeNodeLocalPaths = new Set(Types::String);
    for (xRefPathsLocal = xRefPaths_ds.getFirst(true) ?
        xRefPaths_ds.getFirst(true) : xRefPaths_ds.cursor();
        xRefPathsLocal;
        xRefPathsLocal = xRefPaths_ds.getNext())
        treeNodeLocalPaths.add(xRefPathsLocal.Path);
    if (treeNodeLocalPaths.elements() == 0)
        info("There are no AOT objects to create the project from.");
        return;
    dialog = new dialog("Create project");
    dialogField = dialog.addFieldValue(
        extendedTypeStr(ProjectName),
        'UsedByProject');
    if (dialog.run())
        projectNode = SysTreeNode::createProject(any2str(dialogField.value()));
        project = new SysProjectFilterRunBase();
        project.parmProjectNode(projectNode);
        project.grouping(SysProjectGrouping::AOT);
        treeNodeLocalPathEnumerator = treeNodeLocalPaths.getEnumerator();
        while (treeNodeLocalPathEnumerator.moveNext())
            utilElements = xUtilElements::findTreeNode(
                treeNode::findNode(
                    SysTreeNode::applObjectPath(
                    treeNodeLocalPathEnumerator.current())),
                false);
            if (utilElements.RecId != 0)
                project.doUtilElements(utilElements);
        project.write();
Now, if you select one or more records in the "used by" grid and press the button, a new project will be created:
Plugin не подхватывает создание сущности бизнес-процессом 2rik Dynamics CRM: Разработка 6 21.02.2012 12:09
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
axaptapedia: Create New AOT Project From Template Blog bot DAX Blogs 0 29.08.2008 21:10
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
Часовой пояс GMT +3, время: 22:51.
