Старый 05.09.2011, 18:11   #1
Gareth Tucker: Quick Create Contact from the CRM Case Form
Источник: http://gtcrm.wordpress.com/2011/09/0...crm-case-form/
In a previous post I demonstrated a screen customisation that allows quick creation of a new Contact directly on the Phone Call form.   Today I needed the same thing on the Case form so thought I would share that code here as well.
Here’s what my screen looks like:
The “Quick Create New Citizen” fields are enabled so long as a “Citizen” has not yet been specified on the Case (note: I have renamed Contact to Citizen).   Once you key into one of the Quick Create fields the other Quick Create fields become mandatory.  Once they are all populated a new Citizen/Contact is created and the Case is updated to link to that record.
Here’s the java script:
function SetLookupValue(fieldName, id, name, entityType) {
if (fieldName != null) {
var lookupValue = new Array();
lookupValue[0] = new Object();
lookupValue[0].id = id;
lookupValue[0].name = name;
lookupValue[0].entityType = entityType;
Xrm.Page.getAttribute(fieldName).setValue(lookupValue);
function DisableFields() {
Xrm.Page.ui.controls.get("new_firstname").setDisabled(true);
Xrm.Page.ui.controls.get("new_lastname").setDisabled(true);
Xrm.Page.ui.controls.get("new_phonenumber").setDisabled(true);
function MakeFieldsMandatory() {
Xrm.Page.data.entity.attributes.get("new_firstname").setRequiredLevel("required");
Xrm.Page.data.entity.attributes.get("new_lastname").setRequiredLevel("required");
Xrm.Page.data.entity.attributes.get("new_phonenumber").setRequiredLevel("required");
function MakeFieldsNonMandatory() {
Xrm.Page.data.entity.attributes.get("new_firstname").setRequiredLevel("none");
Xrm.Page.data.entity.attributes.get("new_lastname").setRequiredLevel("none");
Xrm.Page.data.entity.attributes.get("new_phonenumber").setRequiredLevel("none");
function OnLoad() {
if (Xrm.Page.ui.getFormType() == 1) {
else if (Xrm.Page.ui.getFormType() != 1) {
DisableFields();
function NewContact() {
if (
Xrm.Page.getAttribute("new_firstname").getValue() == null &&
Xrm.Page.getAttribute("new_lastname").getValue() == null &&
Xrm.Page.getAttribute("new_phonenumber").getValue() == null) {
MakeFieldsNonMandatory();
else if (
Xrm.Page.getAttribute("new_firstname").getValue() != null &&
Xrm.Page.getAttribute("new_lastname").getValue() != null &&
Xrm.Page.getAttribute("new_phonenumber").getValue() != null &&
Xrm.Page.data.entity.attributes.get("customerid").getValue() == null) {
CreateContact();
Xrm.Page.getAttribute("new_phonenumber2").setValue(Xrm.Page.getAttribute("new_phonenumber").getValue());
DisableFields();
else {
MakeFieldsMandatory();
//Xrm.Page.ui.controls.get("from").setVisible(false);
function CreateContact() {
// Get the CRM URL
var serverUrl = Xrm.Page.context.getServerUrl();
// Cater for URL differences between on premise and online
if (serverUrl.match(/\/$/)) {
serverUrl = serverUrl.substring(0, serverUrl.length - 1);
// Specify the ODATA end point (this is the same for all CRM 2011 implementations)
var ODATA_ENDPOINT = "/XRMServices/2011/OrganizationData.svc";
// Specify the ODATA entity collection
var ODATA_EntityCollection = "/ContactSet";
// Define an object for the CRM record you want created
var CRMObject = new Object();
// Define attribute values for the CRM object
CRMObject.FirstName = Xrm.Page.getAttribute("new_firstname").getValue();
CRMObject.LastName = Xrm.Page.getAttribute("new_lastname").getValue();
CRMObject.Telephone1 = Xrm.Page.getAttribute("new_phonenumber").getValue();
//Parse the entity object into JSON
var jsonEntity = window.JSON.stringify(CRMObject);
//Asynchronous AJAX function to Create a CRM record using OData
$.ajax({
type: "POST",
contentType: "application/json; charset=utf-8",
datatype: "json",
url: serverUrl + ODATA_ENDPOINT + ODATA_EntityCollection,
data: jsonEntity,
beforeSend: function (XMLHttpRequest) {
//Specifying this header ensures that the results will be returned as JSON.
XMLHttpRequest.setRequestHeader("Accept", "application/json");
success: function (data, textStatus, XmlHttpRequest) {
//This function will trigger asynchronously if the Retrieve was successful
//alert("ajax call successful");
var NewCRMRecordCreated = data["d"];
var FullName = Xrm.Page.getAttribute("new_firstname").getValue() + " " + Xrm.Page.getAttribute("new_lastname").getValue();
SetLookupValue("customerid", NewCRMRecordCreated.ContactId, FullName, "contact");
error: function (XmlHttpRequest, textStatus, errorThrown) {
//This function will trigger asynchronously if the Retrieve returned an error
alert("ajax call failed");
The new fields are called new_firstname, new_lastname and new_phonenumber.
You’ll need to add the following libraries and event handler to the Case form’s OnLoad event (I provide a download link to these at the end of this post):
And you will need this event handler added to each of the Quick Create field’s OnChange events:
The 4 web resources employed are available here.
Cheers,
Gareth.
Gareth Tucker: Quick Create Contact from the Phone Call Form Blog bot Dynamics CRM: Blogs 0 23.08.2011 12:11
Gareth Tucker: Building a Microsoft CRM 2011 VM – A Quick Checklist Blog bot Dynamics CRM: Blogs 0 03.08.2011 09:11
Microsoft Dynamics CRM Team Blog: CRM Online: ‘Contact Us’ Web Form Made Easy Blog bot Dynamics CRM: Blogs 0 20.05.2009 05:05
Часовой пояс GMT +3, время: 13:09.
