#1 |
Но имеем: Код: D:\AX Trace>mofcomp.exe aos_trace.mof Microsoft (R) MOF Compiler Version 6.1.7600.16385 Copyright (c) Microsoft Corp. 1997-2006. All rights reserved. Parsing MOF file: aos_trace.mof MOF file has been successfully parsed Storing data in the repository... WARNING: File aos_trace.mof does not contain #PRAGMA AUTORECOVER. If the WMI repository is rebuilt in the future, the contents of this MOF file will not be included in the new WMI repository. To include this MOF file when the WMI Repository is automatically reconstructed, place the #PRAGMA AUTORECOVER statement on the first line of the MOF file. Done! D:\AX Trace>mofcomp.exe ax_trace.mof Microsoft (R) MOF Compiler Version 6.1.7600.16385 Copyright (c) Microsoft Corp. 1997-2006. All rights reserved. Parsing MOF file: ax_trace.mof MOF file has been successfully parsed Storing data in the repository... WARNING: File ax_trace.mof does not contain #PRAGMA AUTORECOVER. If the WMI repository is rebuilt in the future, the contents of this MOF file will not be included in the new WMI repository. To include this MOF file when the WMI Repository is automatically reconstructed, place the #PRAGMA AUTORECOVER statement on the first line of the MOF file. Done! Что делать с WARNING: File ax_trace.mof does not contain #PRAGMA AUTORECOVER.?
This posting is provided "AS IS" with no warranties, and confers no rights. |
#2 |
PHP код:
Код: D:\AX Trace>mofcomp.exe -Autorecover aos_trace.mof Microsoft (R) MOF Compiler Version 6.1.7600.16385 Copyright (c) Microsoft Corp. 1997-2006. All rights reserved. Parsing MOF file: aos_trace.mof MOF file has been successfully parsed Storing data in the repository... Done! D:\AX Trace>mofcomp.exe -Autorecover ax_trace.mof Microsoft (R) MOF Compiler Version 6.1.7600.16385 Copyright (c) Microsoft Corp. 1997-2006. All rights reserved. Parsing MOF file: ax_trace.mof MOF file has been successfully parsed Storing data in the repository... Done! P.S. http://myitforum.com/cs2/blogs/jgilb...r-command.aspx http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
#3 |
Никогда не видел чтобы WMI-база рушилась. Вообще эта прагма, судя по всему, была придумана для автовосстановления некоторых критических системных счетчиков производительности, чтобы даже если у тебя компьютер был очень сильно поеден вирусами, при старте он смог бы как-то восстановить WMI-database и откликнуться на зов System Center. Поскольку отладачная печать Аксапты, это явно не критический системный счетчик, думаю можно запросто жить без этой прагмы. ![]() |
Теги |
trace parser |
Опции просмотра | |
