Старый 21.03.2007, 22:31   #1
axaptapedia: Change table owner
Источник: http://www.axaptapedia.com/Change_table_owner
Summary:
This is more a MSSQL-tips, but it can be usefull for Axapta when you attach a existing database to your MSSQL-server. Sometimes the user of the attached database has the same name as the one already declared in MSSQL-server. Then use this code to generate another code who change the ownershop of each table in the attached database:
SELECT 'exec sp_changeobjectowner ''' + ltrim(u.name) + '.' + ltrim(s.name) + ''',' + '''dbo'''
FROM sysobjects s,sysusers u
WHERE s.uid = u.uid AND
u.name 'dbo' AND
xtype in ('V', 'P', 'U') AND
u.name not like 'INFORMATION%'
order by s.name
This scripts do actual update:
declare @@name nvarchar(517)
declare tables cursor for
select
u.name + '.' + o.name
from
sysobjects o inner join
sysusers u on (o.uid = u.uid)
where
type in ('U', 'V') and u.name = 'bmssa'
-- Name ^^^^^ sholuld be replaced
open tables
fetch from tables into @@name
while @@fetch_status = 0
begin
exec sp_changeobjectowner @@name, 'dbo'
end
close tables
deallocate tables
--[[User:Codewire.net|CODEWIRE.NET]] 06:36, 12 March 2007 (EDT)
Старый 22.03.2007, 20:56   #2
glibs is offline
glibs
Member
Сотрудники компании It Box
4,942 / 911 (40) +++++++
На Technet как-то давно предлагали более изящный способ
sp_msforeachtable "sp_changeobjectowner '?', 'dbo'"
(этот текст нужно набрать и запустить в Query Analyser, выбрав нужную базу).
glibs®
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
axaptapedia: Go To Main Table Blog bot DAX Blogs 0 15.08.2007 19:40
axaptapedia: Export a table to Excel Blog bot DAX Blogs 0 27.04.2007 11:10
axaptapedia: Export a table to Excel Blog bot DAX Blogs 0 12.04.2007 16:10
axaptapedia: Change table owner Blog bot DAX Blogs 0 12.03.2007 17:30
Часовой пояс GMT +3, время: 04:34.
