#9 |
Можно так:
DECLARE @pagesizeKB int SELECT @pagesizeKB = low / 1024 FROM master.dbo.spt_values WHERE number = 1 AND type = 'E' SELECT table_name = OBJECT_NAME(o.id), rows = i1.rowcnt, reservedKB = (ISNULL(SUM(i1.reserved), 0) + ISNULL(SUM(i2.reserved), 0)) * @pagesizeKB, dataKB = (ISNULL(SUM(i1.dpages), 0) + ISNULL(SUM(i2.used), 0)) * @pagesizeKB, index_sizeKB = ((ISNULL(SUM(i1.used), 0) + ISNULL(SUM(i2.used), 0)) - (ISNULL(SUM(i1.dpages), 0) + ISNULL(SUM(i2.used), 0))) * @pagesizeKB, unusedKB = ((ISNULL(SUM(i1.reserved), 0) + ISNULL(SUM(i2.reserved), 0)) - (ISNULL(SUM(i1.used), 0) + ISNULL(SUM(i2.used), 0))) * @pagesizeKB FROM sysobjects o LEFT OUTER JOIN sysindexes i1 ON i1.id = o.id AND i1.indid < 2 LEFT OUTER JOIN sysindexes i2 ON i2.id = o.id AND i2.indid = 255 WHERE OBJECTPROPERTY(o.id, N'IsUserTable') = 1 --same as: o.xtype = %af_src_str_2 OR (OBJECTPROPERTY(o.id, N'IsView') = 1 AND OBJECTPROPERTY(o.id, N'IsIndexed') = 1) GROUP BY o.id, i1.rowcnt ORDER BY 3 DESC но это уже www.sql.ru |
