Старый 27.06.2019, 12:33   #1
Logger is offline
3,987 / 3273 (117) ++++++++++
create procedure sys.sp_tables при синхронизации
Привет всем.
Помогите разобраться.
Axapta 2012 R3 CU13
Запустил полную синхронизацию базы.
Раз в 10 секунд проскакивает запрос
create procedure sys.sp_tables  (      @table_name         nvarchar(384)   = null,      @table_owner        nvarchar(384)   = null,      @table_qualifier    sysname = null,      @table_type         varchar(100) = null,      @fUsePattern        bit = 1 -- To allow users to explicitly disable all pattern matching.  )  as      declare @type1      varchar(3)      declare @qual_name  nvarchar(517) -- [schema].[table]      declare @table_id   int        if @table_qualifier = '%' and @table_owner = '' and @table_name = ''      begin          -- Debug output, do not remove it.          -- print 'Special feature #1:  enumerate databases when owner and name are blank but qualifier is explicitly "%".'          select              TABLE_QUALIFIER = convert(sysname,d.name),              TABLE_OWNER     = convert(sysname,null),              TABLE_NAME      = convert(sysname,null),              TABLE_TYPE      = convert(varchar(32),null),              REMARKS         = convert(varchar(254),null)    -- Remarks are NULL.          from              sys.databases d          where              d.name <> 'model' -- eliminate MODEL database          order by 1          return      end        if @table_qualifier = '' and @table_owner = '%' and @table_name = ''      begin          -- Debug output, do not remove it.          -- print 'Special feature #2:  enumerate owners when qualifier and name are blank but owner is explicitly "%".          select distinct              TABLE_QUALIFIER = convert(sysname,null),              TABLE_OWNER     = convert(sysname,schema_name(o.schema_id)),              TABLE_NAME      = convert(sysname,null),              TABLE_TYPE      = convert(varchar(32),null),              REMARKS         = convert(varchar(254),null)    -- Remarks are NULL.          from              sys.all_objects o          where              o.type in ('S','U','V')  -- limit columns to tables and views only          order by 2          return      end        if @table_qualifier = '' and @table_owner = '' and @table_name = '' and @table_type = '%'      begin          -- Debug output, do not remove it.          -- print 'Special feature #3:  enumerate table types when qualifier, owner and name are blank but table type is explicitly "%".'          select              TABLE_QUALIFIER = convert(sysname,null),              TABLE_OWNER     = convert(sysname,null),              TABLE_NAME      = convert(sysname,null),              TABLE_TYPE      = convert(varchar(32),                                          rtrim(substring('SYSTEM TABLETABLE       VIEW',(c.column_id-1)*12+1,12))),              REMARKS         = convert(varchar(254),null)    -- Remarks are NULL.          from              sys.all_objects o,              sys.all_columns c          where              o.object_id = c.object_id and o.object_id = object_id('sysusers') and              c.column_id <= 3 -- ISSUE - what is this for ???          return      end        --      -- End of special features - do normal processing.      --        if @table_qualifier is not null      begin          if db_name() <> @table_qualifier          begin              if @table_qualifier = ''              begin  -- If empty qualifier supplied, force an empty result set.                  select @table_name = ''                  select @table_owner = ''              end              else              begin   -- If qualifier doesn't match current database.                  raiserror (15250, -1,-1)                  return              end          end      end      select @table_qualifier = null -- it's not needed anymore        if @table_type is null      begin   -- Select all ODBC supported table types.          select @type1 = 'SUV'      end      else      begin          -- TableType is case sensitive if CS server.          if (charindex('''SYSTEM TABLE''',@table_type) <> 0)              select @type1 = 'S' -- Add System Tables.          else              select @type1 = ''          if (charindex('''TABLE''',@table_type) <> 0)              select @type1 = @type1 + 'U' -- Add User Tables.          if (charindex('''VIEW''',@table_type) <> 0)              select @type1 = @type1 + 'V' -- Add Views.      end        if @table_name is not null      begin          if (@table_owner is null) and (charindex('%', @table_name) = 0)          begin   -- If owner not specified and table contains wildchar.              if exists              (                  select                          *                  from                          sys.all_objects o                  where                          o.schema_id = schema_id() and                          o.object_id = object_id(@table_name) and                          o.type in ('U','V','S')              )              begin   -- Override supplied owner w/owner of table.                  select @table_owner = schema_name()              end          end      end        select @qual_name = isnull(quotename(@table_owner), '') + '.' + quotename(@table_name)      select @table_id = object_id(@qual_name)        if (@fUsePattern = 1) -- Does the user want it?      begin          if ((isnull(charindex('%', @table_name),0) = 0) and              (isnull(charindex('_', @table_name),0) = 0) and              (isnull(charindex('%', @table_owner),0) = 0) and              (isnull(charindex('_', @table_owner),0) = 0) and              (@table_id is not null))          begin              select @fUsePattern = 0 -- not a single wild char, so go the fast way.          end      end        if @fUsePattern = 0      begin          /* -- Debug output, do not remove it.          print '*************'          print 'There is NO pattern matching.'          print @fUsePattern          print isnull(@table_name, '@table_name = null')          print isnull(@table_owner, '@table_owner = null')          print isnull(@table_type, '@table_type = null')          print isnull(@type1, '@type1 = null')          print '*************'          */          select              TABLE_QUALIFIER = convert(sysname,db_name()),              TABLE_OWNER     = convert(sysname,schema_name(o.schema_id)),              TABLE_NAME      = convert(sysname,o.name),              TABLE_TYPE      = convert(varchar(32),                                          rtrim(substring('SYSTEM TABLE            TABLE       VIEW       ',                                          (ascii(o.type)-83)*12+1,12))  -- 'S'=0,'U'=2,'V'=3                                       ),              REMARKS = convert(varchar(254),null)    -- Remarks are NULL.            from              sys.all_objects o            where              o.object_id = @table_id and              (o.type in ('U','V') or                   (o.type in ('S') and has_perms_by_name(@qual_name, 'object', 'select') = 1)) and              charindex(substring(o.type,1,1),@type1) <> 0 -- Only desired types.          order by 4, 1, 2, 3      end      else      begin          /* -- Debug output, do not remove it.          print '*************'          print 'THERE IS pattern matching!'          print @fUsePattern          print isnull(@table_name, '@table_name = null')          print isnull(@table_owner, '@table_owner = null')          print isnull(@table_type, '@table_type = null')          print isnull(@type1, '@type1 = null')          print '*************'          */          select              TABLE_QUALIFIER = convert(sysname,db_name()),              TABLE_OWNER     = convert(sysname,schema_name(o.schema_id)),              TABLE_NAME      = convert(sysname,o.name),              TABLE_TYPE      = convert(varchar(32),                                          rtrim(substring('SYSTEM TABLE            TABLE       VIEW       ',                                                (ascii(o.type)-83)*12+1,                                                12))  -- 'S'=0,'U'=2,'V'=3                                       ),              REMARKS = convert(varchar(254),null)    -- Remarks are NULL.            from              sys.all_objects o            where              (o.type in ('U','V') or                   (o.type in ('S') and has_perms_by_name(quotename(schema_name(o.schema_id)) + '.' + quotename(o.name), 'object', 'select') = 1)) and              charindex(substring(o.type,1,1),@type1) <> 0 and -- Only desired types.              (@table_name  is NULL or o.name like @table_name) and              (@table_owner is NULL or schema_name(o.schema_id) like @table_owner)          order by 4, 1, 2, 3      end
зачем ей это ?
Хранимка уже есть, зачем постоянно пытаться ее создавать ?
stoneridgesoftware: Top Tips for Microsoft Dynamics AX Performance Optimization: Part I – Purging data from tables Blog bot DAX Blogs 0 24.06.2017 03:33
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
emeadaxsupport: Temporary Tables (AX 2012) Blog bot DAX Blogs 2 10.08.2012 10:24
axperf: Create RecID index on tables with Created/Modified DateTime fields Blog bot DAX Blogs 0 20.06.2009 10:05
Часовой пояс GMT +3, время: 16:36.
