Старый 08.08.2018, 14:11   #1
crmtipoftheday: Tip #1148: Use visual controls + calculated fields to create an in-form dashboard
Источник: https://crmtipoftheday.com/1148/use-...orm-dashboard/
Want to add some sizzle to you form configuration? David Reinsvold recommends using visual controls with calculated fields to create a nice looking dashboard in your Dynamics 365 Unified Interface form. The following is an example of an investor form that visually displays relevant investor data.
Let’s take a closer look at how this is built:
  1. Current Year return
  • Calculated Field
  • Data Type: Decimal Number
  • Field Type: Calculated
  • ((new_investmentvalue – new_investmentvaluejan1) / new_investmentvalue) * 100
  • Control: Arc Knob
  • Value: hsl_currentyearreturn
  • Min: .1
  • Max: 15
  • Step: .1
2. Return vs. Goal
  • (new_investmentvalue / new_investmentgoal) * 100
  • Control: Arc Knob
  • Value: hsl_goalprogress
  • Min: 0
  • Max: 100
  • Step: 1
By combining visual controls with calculated fields you can easily add visual context to a record and give your users a richer user experience.
Thanks for the tip, David. Do you have a tip for us? Send it to jar@crmtipoftheday.com.
(Facebook and Twitter cover photo by Paula May on Unsplash)
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Мелкомягкий CRM: Панель управления для MS CRM с помощью Reporting Services Blog bot Dynamics CRM: Blogs 1 24.08.2009 14:41
Часовой пояс GMT +3, время: 08:15.
