Старый 03.02.2018, 01:15   #1
Parallel Items/Product Validating or Deleting
Источник: http://alexvoy.blogspot.com/2018/02/...dating-or.html
If you need to validate or delete items/products or any other records in a BIG number, it is better to run such processing, first, in CIL, second in parallel threads.
This project is to demonstrate this approach.
The whole concept is similar to what I explained in one of my previous blogpost about Multi thread parallelism and a dispatching table for finding a minimum
wblInventItemProcessBatch class populates a special table containing RecIds to be processed and thread number they belong to.
Based on the user selection, it creates appropriate number of batch tasks that can run independently with their progress percentage.
Feel free to elaborate this project by adding new types of processing or new table to process. Also it is probably a good idea to add a new column to the table to separate different instances wblInventItemProcessBatch simultaneously running in the same environment.
private static server int64 populateItems2Process(str 20 _what2find, int _batchThreads)
wblInventItemProcessTable wblInventItemProcessTable;
InventTable inventTable;
int firstThread = 1;
Counter countr;
// flush all previously created items from the table
delete_from wblInventItemProcessTable;
// insert all needed items in one shot. this part can be refactored to use Query instead
insert_recordset wblInventItemProcessTable (threadNum, ItemRecId, ItemId)
select firstThread, RecId, ItemId from InventTable
where
inventTable.itemId like _what2find;
// now group them in threads by simply enumerating them from 1 to N
countr=1;
ttsBegin;
while select forUpdate wblInventItemProcessTable
wblInventItemProcessTable.threadNum = countr;
wblInventItemProcessTable.update();
countr++;
if(countr > _batchThreads)
countr=1;
ttsCommit;
// return the total number of items to process
select count(RecId) from wblInventItemProcessTable;
return wblInventItemProcessTable.RecId;
public void run()
// get all required items by their RecIds in the table and group them in threads
int64 totalRecords = wblInventItemProcessBatch::populateItems2Process(what2find, batchThreads);
if(totalRecords)
info(strFmt("Found %1 items like '%2' to %3", totalRecords, what2find, processType));
// create number of batch tasks to parallel processing
this.scheduleBatchJobs();
else
warning(strFmt("There are no items like '%1'", what2find));
wblInventItemProcessTask process()
... select count(RecId) from inventTable
exists join wblInventItemProcessTable
where
wblInventItemProcessTable.ItemRecId == inventTable.RecId &&
wblInventItemProcessTable.threadNum == threadNum;
// total number of lines to be processed
totalLines = inventTable.reciD;
// to enjoy our bored user during a few next hours
// this progress just updates percentage in Batch task form
progressServer = RunbaseProgress::newServerProgress(1, newGuid(), -1, DateTimeUtil::minValue());
progressServer.setTotal(totalLines);
while select inventTable
where
progressServer.incCount();
try
// RUN YUR LOGIC HERE //////////////////////
Kashperuk Ivan: Tutorial: Update product receipts for loads and how to handle items missing from ASN Blog bot DAX Blogs 0 22.09.2014 18:11
DynamicsAxSCM: Understanding the product validation process in Dynamics AX 2012 Blog bot DAX Blogs 0 07.12.2012 03:12
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
Часовой пояс GMT +3, время: 20:45.
