29.10.2017, 13:11 | #1 |
sinedax: Setup the AOS Balancing on AIF WEB Services or WHS Mobile Portal - AX 2012
Источник: http://sinedax.blogspot.com/2017/10/...-services.html
============== Hi Guys In an AX Environment with a huge AX Services workload, it is suggested to enable the AX Services Balance. In order to do that, you have to:
Talking about AIF Web Services or WHS Mobile Portal, in some cases, you have to create also an IIS Farm in order to balance the IIS Connections. If you are working on Azure you have to use the Azure Application Gateway in order to do that. Till Soon! Источник: http://sinedax.blogspot.com/2017/10/...-services.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
Теги |
ax2012, load balancing |
