Старый 14.09.2017, 13:11   #1
axatoz: LCS – Issue search can’t find other AX versions
Источник: https://axatoz.wordpress.com/2016/05...r-ax-versions/
Issue
I went to LCS to find whether or not an issue is a bug recently. No matter what I tried in the search box, it only returned results for AX7. I was looking for an in issue in R3. Where are the other versions? I used to be able to filter under PRODUCT. I was so frustrated because I used to be able to filter by the PRODUCT category.
Solution
This is the url after I searched
https://fix.lcs.dynamics.com/Issue/R...u=&pi=&pm=&pc=
Then I changed it to
https://fix.lcs.dynamics.com/Issue/Results/
Now I’m able to search with anything with different product versions.
atinkerersnotebook: The New Dynamics AX Tip #10: Using the search feature to fund functions Blog bot DAX Blogs 0 08.01.2016 15:11
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: Managing general performance issues in Microsoft Dynamics AX Blog bot DAX Blogs 0 12.09.2014 12:11
kamalblogs: Issue: Dimension lookup “selected record invisible” – Dynamics AX 2012 Blog bot DAX Blogs 0 07.10.2013 13:11
Часовой пояс GMT +3, время: 07:41.
