Старый 10.08.2017, 14:11   #1
mfp: Extensible Inventory Dimensions
Источник: https://blogs.msdn.microsoft.com/mfp...ry-dimensions/
Background Adding new inventory dimensions is currently impossible without succumbing to overlayering. As you are reading my blog, you'll know we need an extensible alternative. This post outlines the solution we are proposing to enable extensible inventory dimensions. There are several technical limitations influencing the design of the proposed solution. The most significant is the...
d365fo, inventdim, inventory dimensions
emeadaxsupport: Inventory value report doesn’t show some inventory dimensions. Blog bot DAX Blogs 0 03.01.2017 22:12
ax-erp: Inventory dimensions as parameters in the SSRS reports – InventDimViewContract class[Dynamics AX 2012] Blog bot DAX Blogs 0 18.07.2012 19:11
axinthefield: Reconciling Inventory to GL in Dynamics AX Blog bot DAX Blogs 0 23.04.2011 00:17
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Часовой пояс GMT +3, время: 14:20.
