Старый 09.02.2017, 17:43   #1
Gatta is offline
Gatta
How To control the decimal point in Real values in Dynamics AX365 ?
Hi!!
Could you help me please? I know how to control the decimal point in Real values in Dynamics AX 2009. But Dynamics 365 is totally different.
So,
To control the decimal point in real value in AX 2009 I do the following :
1- right click on the real field and choose properties
2- go to NoOfDecimals property and put any number you want for example (1 or 2 or 3)
This means the numbers after the decimal point example :
if the value is 2.31689
if you put 1 the result is 2.3
if you put 2 the result is 2.31
Thanks in advance!!
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Security How-To' Blog bot DAX Blogs 0 13.12.2012 01:13
axblog4u: Tip: COMVariantType for Real values in Dynamics AX Blog bot DAX Blogs 0 06.09.2012 18:11
AIF: How to serialize int/real properties with 0/0.00 values via AIF outbound integration Blog bot DAX Blogs 0 08.05.2012 04:13
Часовой пояс GMT +3, время: 11:16.
