Старый 05.10.2016, 01:14   #1
organicax: Critical on-hand inventory report AX7
Источник: https://organicax.com/2016/10/04/cri...ry-report-ax7/
There is a handy report called the critical on-hand inventory report that you can use as a check for items that might have got below a minimum. This will let you check if there is something ordered which will give you an indication that you might need to investigate the replenishment of the item.
You will see in the video that the reports runs off the coverage settings so if you have an item on the report that is below a min and you were expecting inventory then you might need to investigate the item for example the inventory was put in the wrong warehouse or you didn’t have coverage settings setup.
Here is a quick overview.
AX7 Build 7.0.4230.16130
If you are looking are working with AX2012 you can see the same in this post.
Cheers
Lachlan
Filed under: Supply chain planning
organicax: Critical on-hand inventory report Blog bot DAX Blogs 0 03.10.2016 23:12
NAV Team: Report Execution Insights Blog bot Dynamics CRM: Blogs 0 30.10.2014 15:02
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Часовой пояс GMT +3, время: 12:02.
