Старый 03.11.2014, 20:20   #1
To check if a BLOB field has a value, you call its HASVALUE function. For example: IF Item.Picture.HASVALUE THEN;
In older versions, earlier than NAV 2009, you had to call CALCFIELDS before you could check HASVALUE, which – if you think of it, did not make much sense. This was changed in NAV 2009, so ever since that version you can check HASVALUE before you decide to call CALCFIELDS first. It makes all the sense – you don’t need to pull up to 2GB of data over just to see if anything is inside.
If you are an old-school guy (or just old, as me), and you CALCFIELDS first, HASVALUE next, maybe it’s time for you to reconsider it.
Rembember – the pattern is: IF Field.HASVALUE THEN Rec.CALCFIELDS(Field);
Read this post at its original location at http://vjeko.com/blog/value-mr-blob, or visit the original blog at http://vjeko.com. 5e33c5f6cb90c441bd1f23d5b9eeca34The post Do you have a value, Mr. BLOB? appeared first on Vjeko.com.
</img> </img>
Читать дальше
Часовой пояс GMT +3, время: 01:25.
