Старый 06.09.2012, 16:41   #1
Hi all,
I just want to let you know some more details about “how to convert a NAV 2009 database to NAV 2013”
First of all we have to take a look on some restrictions:
It is not supported to restore a NAV backup from NAV 2009 to NAV 2013  directly
It is not supported to open a NAV 2009 Database, without changing some settings, with Development Environment of NAV 2013
So here are the steps you have to do to “convert” the database to NAV 2013.
(some of the steps can be done in reverse order)
  1. Open your NAV 2009 Client and navigate to the object designer
  2. Remove (and/or save and then remove) all your Forms and Dataport objects (are not supported in NAV 2013 – you will not be able to convert if you skip this step)
  3. Create a SQL backup of your NAV 2009 DB (is not required if you already on a 64 Bit server)
  4. Restore it on your new 64 Bit SQL Server (is not required if you already on a server like this)
  5. Open the SQL Management Studio and navigate to your database
  6. Right Mouse click – and open the properties
  7. Navigate to the Options Group and change the compatibility level to 100 (if it is <=90)
  8. Confirm it by clicking ok
  9. Return to NAV 2013 development environment and open the database
  10. Typically “converting dialog” appears.
  11. Go ahead converting the database
Notice: this is NOT the data migration or object migration (business logic transformation) process. It is just the first step you have to do before moving forward working with the database with NAV 2013 development environment.
Далее
Часовой пояс GMT +3, время: 00:28.
