Старый 01.08.2015, 04:24   #1
lcs: July 2015 release notes
Источник: http://blogs.msdn.com/b/lcs/archive/...ase-notes.aspx
The Microsoft Dynamics Lifecycle Services team is happy to announce the immediate availability of the July release of Lifecycle Services.
NEW FEATURES
General
  • You can now submit an ERP translation support request for Microsoft Dynamics AX 2012. Details on how you can use this feature can be found here. (This is a Preview Feature.)
  • You can now deploy Microsoft Dynamics AX 2012 R3 CU9 evaluation version from Azure marketplace.
Business process modeler
At a parent level, you can now combine all child flow charts to make a consolidated view of all child process lines by clicking Compose child lines.
You can revert this change by clicking Clear composed line.
Cloud-hosted environments
  • Microsoft Dynamics AX 2012 R3 topologies now default to deploying Dynamics AX 2012 CU9. To deploy prior versions of Dynamics AX, click Advanced Settings > Supported Versions.
  • Dynamics AX 2012 R3 topologies, excluding Demo, now support SQL Server Disk customizations where #disks and disk sizes can be customized in Advanced Settings.
Update Experience
The new update experience which was made available during the May update for Dynamics AX 2012 R3 is now available for Microsoft Dynamics AX 2012 R2. In order to use this experience, you must have System diagnostics enabled for your AX 2012 R2 environment and this experience is best designed for customers who are on R2 CU7 or R2 CU8.
Private Preview Features - Known issues:
In the Microsoft Dynamics 'AX 7' Technical Preview, you will experience issues when trying to save a task recording output to LCS. At this time, there is no workaround for the issue.
lcs: June 2015 release notes Blog bot DAX Blogs 0 07.07.2015 05:12
lcs: May 2015 release notes Blog bot DAX Blogs 0 01.06.2015 23:13
lcs: April 2015 release notes Blog bot DAX Blogs 0 20.04.2015 19:12
lcs: February 2015 release notes Blog bot DAX Blogs 0 23.02.2015 09:15
lcs: July release notes Blog bot DAX Blogs 0 09.07.2014 20:12
Часовой пояс GMT +3, время: 16:17.
