Старый 02.08.2014, 16:11   #1
goshoom: Operand types are not compatible
Источник: http://dev.goshoom.net/en/2014/08/op...ot-compatible/
I managed to produce a really confusing error in AX 2012. Look at the following piece of code:
MyExtendedDataType a, b; a = b;
Pretty boring, isn’t it? There is nothing to fail… except that I got a compilation error: Operand types are not compatible with the operator. What?
Actually it become quite clear as soon as I simplified my code to this trivial example. There is clearly nothing wrong with my code, it must have something to do with the data type.
To make a long story short, I created a new extended data type of type enum and forgot to fill in the EnumType property. Linking the EDT to an enum instantly solved the problem.
But beware – the compiler won’t detect many other uses of this incorrectly-defined type. For example, MyExtendedDataType a = NoYes::Yes; is compilable X++ code even if MyExtendedDataType has empty EnumType.
goshoom: Target date not found in work calendar Blog bot DAX Blogs 0 30.01.2014 16:11
goshoom: Daily or not daily Blog bot DAX Blogs 0 11.06.2013 07:12
Часовой пояс GMT +3, время: 22:02.
