Старый 28.06.2014, 00:13   #1
Dynamics AX Sustained Engineering: An important hotfix is available for Microsoft Dynamics AX 2012 R2 that resolves duplicate key error when DATAAREAIDLITERAL is enabled on
Источник: http://blogs.technet.com/b/dynamicsa...nabled-on.aspx
Issue
Some customers have recently been hitting a duplicate key error on Dynamics AX 2012 R2 when literals are turned on for DATAAREAID and partition columns via configuration settings. The issue happens while switching companies or while starting AX in another partition.
This is caused by a bug related to queries that are joining a company specific table with a non company specific table after switching companies and when the DATAREAIDLITERAL server config option is turned on. In essense, data is not being retrieved in the company specific table on an outer join, and nothing is retrieved on an inner join after switching companies. The workaround is to turn off DATAAREAIDLITERAL flag.
Applicability
The issue occurs on a particular Dynamics AX 2012 R2 environment under the following circumstances
  • AX 2012 R2 environment has a kernel build between 6.2.1000.7442 and 6.2.1000.7876
  • Literals are turned on for DATAAREAID and partition columns on SysGlobalConfiguration
Recommendation
We have addressed the root cause of the issue and the fix is available in the kernel builds 6.2.1000.7877 and later.
If you have experienced this issue, the recommendation is to apply the latest kernel build. AOS server must be restarted for the fix to take effect.
Dynamics AX Sustained Engineering: Announcing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 15.12.2013 02:18
Dynamics AX Sustained Engineering: Announcing Cumulative Update 5 for Microsoft Dynamics AX 2012 & Microsoft Dynamics AX 2012 Feature Pack 1 Blog bot DAX Blogs 0 30.04.2013 01:13
Cumulative Update 1 for Microsoft Dynamics AX 2012 R2 Vadik DAX: База знаний и проекты 2 02.03.2013 10:14
Dynamics AX Sustained Engineering: Servicing of Dynamics AX 2012 and Dynamics AX 2012 Feature Pack Blog bot DAX Blogs 0 08.05.2012 23:12
Часовой пояс GMT +3, время: 18:31.
