Старый 20.11.2013, 03:16   #1
mfp: X++ Debugging Tips and Tricks #3–Conditional breakpoints
Источник: http://blogs.msdn.com/b/mfp/archive/...eakpoints.aspx
The Dynamics AX Debugger doesn’t support conditional breakpoints. Once in a while this limitation can be quite annoying – but there is a simple workaround. The third trick in the series of X++ Debugging Tips and Tricks shows you how.
This trick requires code instrumentation – I strongly discourage using this trick on a production system. Only use this trick in a test or development sandbox!
By using the breakpoint keyword, you can write X++ logic that triggers a breakpoint exactly as you want.
Consider this example. It is a recursive implementation of the mathematical function: Factorial. On a 32 bit system it will overflow when called with a sufficient high value. The example shows how to a breakpoint when an overflow occurs.
static void ConditionalBreakpointExample(Args args) { int factorial(int _value) { int result = 1; int prevResult; int i; for (i=1; i
mfp: X++ Debugging Tips and Tricks #2 – xSession::xppCallStack() Blog bot DAX Blogs 6 23.11.2015 11:37
mfp: X++ Debugging Tips and Tricks Blog bot DAX Blogs 2 24.09.2013 13:01
mfp: X++ Debugging Tips and Tricks #1 – Breakpoint in Info.add() Blog bot DAX Blogs 1 24.09.2013 11:00
sumitax: EP Debugging Tips and Tricks –Part III Blog bot DAX Blogs 0 13.10.2010 14:05
sumitax: EP Debugging Tips and Tricks –Part II Blog bot DAX Blogs 0 30.09.2010 09:05
Часовой пояс GMT +3, время: 08:40.
