Старый 19.09.2012, 20:11   #1
emeadaxsupport: Cycle counting list report does not display warehouse and locations
Источник: http://blogs.msdn.com/b/axsupport/ar...locations.aspx
If you are seeing this make sure to check your license configuration found in System administration>Setup>Licensing>License configuration and look at the Warehouse management II>Pallets box. If pallets is unchecked this will prevent warehouse and locations from printing on the counting sheet report.
emeadaxsupport: How to import default site and warehouse locations for a product using services (AIF) Blog bot DAX Blogs 0 10.07.2012 00:11
dynamicsaxtraining: Production life cycle Blog bot DAX Blogs 0 16.07.2011 01:23
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
Kurt Hatlevik: Warehouse Management and Distribution for Dynamics AX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
Kurt Hatlevik: Warehouse Management and Distribution for Dynamics AX 2009 Blog bot DAX Blogs 0 20.11.2008 01:10
Часовой пояс GMT +3, время: 03:43.
