		#1 |
			crminthefield: ReportingAccountMemberOfSecurityGroupValidator Error When Installing CRM 2011 Reporting Extensions
			Источник: http://blogs.msdn.com/b/crminthefiel...xtensions.aspx
			============== I recenty worked through an issue where a customer was receiving the following error when attempting to install the CRM 2011 Reporting Extensions: Check ReportingAccountMemberOfSecurityGroupValidator : Failure: A Microsoft Dynamics CRM Server component is using the same account as the instance of SQL Server Reporting Services. This error can occur for a variety of reasons. One reason can be related to the SQL Reporting Services service being started by a domain account and when that account is a member of the SQLAccessGroup, you will see the previously mentioned error. To get past this issue, you have two options:
 Microsoft Dynamics CRM Reporting Extensions should not be installed on an instance of Microsoft SQL Server Reporting Services that is running under an account that is a member of the SQL Access Group. This can occur when Microsoft SQL Server Reporting Services is running under the same account as a Microsoft Dynamics CRM Server 2011 component. This configuration can make the system vulnerable to certain attacks. During installation, Setup detects this scenario. Thank you, Jon Источник: http://blogs.msdn.com/b/crminthefiel...xtensions.aspx
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
