Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 20.02.2011, 14:06   #1
ist is offline
ist
Ax2009SP1_EE_RU6 compiler errors
Hello,
I have installed RU6 on Ax2009SP1 with Eastern Europe and have passed all steps on the upgrade check list. After that I have started a compilation again. The compiler has reported some errors. One of the errors especially worried me.
class PurchFormLetter mehod chooseLine (wich have a copy on the sys and glp layers) use two variables that has not been declared in the classDeclatation method on the class, nor yet in his parrent class FormLetter. The error message is: Variable currentPostingProfile has not been declared.
Is anyone encountered this problem ?
Thank you in advance.
emeadaxsupport: When using AX 2009 AIF Web Services errors may not always get propagated Blog bot DAX Blogs 0 09.11.2010 19:04
dynamics-ax-dev: CLR Errors & ttsbegin/ttscommit Blocks Blog bot DAX Blogs 0 02.11.2010 18:05
X++: Is the X++ Compiler Too Flexible? Blog bot DAX Blogs 17 03.03.2009 17:11
DAX 4 SP2 FP1 EE xshaman DAX: Программирование 8 09.09.2008 15:13
Issues concerning X++: Correction guide - Compiler warnings Blog bot DAX Blogs 0 30.08.2007 04:41
Часовой пояс GMT +3, время: 04:43.
