Старый 01.04.2009, 07:55   #21
vital.mih is offline
vital.mih
var invite4 =  GetAttributeValueFromID('new_date_protocol', crmForm.all.new_protocolsfordate.DataValue[0].id, 'new_invite4');
crmForm.all.new_invite.DataValue=invite4
function GetAttributeValueFromID(sEntityName, GUID, sAttributeName)
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "";
xml = xml+"<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entityName>"+sEntityName+"</entityName>"+
"<id>"+GUID+"</id>"+
"<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+
"<q1:Attributes>"+
"<q1:Attribute>"+sAttributeName+"</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
var result = resultXml.selectSingleNode("//q1:" + sAttributeName).nodeTypedValue;
if (errorCount != 0)
 var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
result = " ";
// Display the retrieved value.
else
alert('test')
return result;
Сначала показывает test, а затем нижеописанное сообщение
Последний раз редактировалось vital.mih; 01.04.2009 в 07:59.
Как получить значение поля одной сущности при обработке формы другой сущности zhenek Dynamics CRM: Разработка 25 05.07.2011 16:19
Получение атрибута из другого объекта Казарин Александр Dynamics CRM: Разработка 6 20.10.2008 18:08
Создание объекта сущности из другого объекта! SnSS Dynamics CRM: Разработка 5 29.05.2008 13:38
Отнимание одного значения от другое pkost Dynamics CRM: Разработка 2 14.03.2008 07:48
Rollup 2 и обкрытие атрибута сущности для кастомизации AHAPX1CT Dynamics CRM: Администрирование 1 23.08.2007 13:45
Часовой пояс GMT +3, время: 02:16.
