Старый 18.10.2008, 02:08   #1
initParmDefault()
Источник: http://alexvoy.blogspot.com/2008/10/...rmdefault.html
Just to remember: if you want to set up some value to a field on a dialog by default you should override standard method initParmDefault().
First time, AX takes it as a value, then it saves and restores the values the user input in the dialog form.
To see how it works just override this method for the class TestDemoRunBaseBacth as the following:
public void initParmDefault()
super();
i=11;
}All values saved by Pack()method can be seen in Usage Data form: Tools\Options\Usage Data [Jobs - for classes]
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
Часовой пояс GMT +3, время: 06:36.
