Старый 26.02.2007, 18:40   #1
casperkamal: InventDim id blank from "Axapta" to "AllBlank" in Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!233.entry
 Hey,
         Just found out something interesting, the blank inventDimid(With all Inventory Dimesions blank) "Axapta" is no more the same, now it is refferred to "AllBlank". I found it as i was digging to find the reason behind no records getting displayed in the "Item" form when I had records in the table.
The problem was the blank record in InventItemLocation, just a wrote a little job to get the things right.
Just copy and run it, if you find a bit lazy to write ....
static void JobChangeAxaptatoBlankInventDim(Args _args)
    InventItemLocation inventItemLocation;
    while select forupdate inventDimId from inventItemLocation
        ttsbegin;
        if (inventItemLocation.inventDimId == 'Axapta')
            inventItemLocation.inventDimId = 'AllBlank';
            inventItemLocation.update();
        ttscommit;
 ..................what else ??????? will see....
palleagermark: The book "Dynamics AX: A Guide to Microsoft Axapta" is available on Google Books Blog bot DAX Blogs 0 10.02.2009 15:05
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Dynamics AX: ERP Live? "Software plus Services"? Blog bot DAX Blogs 0 22.04.2007 20:51
Dynamics AX: Why Dynamics AX beats SAP Blog bot DAX Blogs 0 10.01.2007 23:15
Dynamics AX: Dynamics AX - "Snap to it!" - Part I Blog bot DAX Blogs 0 01.12.2006 21:40
Часовой пояс GMT +3, время: 12:33.
