Старый 10.09.2021, 04:44   #1
d365technext: User Interface Builder Class
Источник: https://d365technext.blogspot.com/20...assD365FO.html
What Is User Interface Builder Class
The User Interface Builder Class is the layout parameter dialog box that opens when a report is running in the Microsoft Dynamics AX Or Finance & Operations.
The User Interface also adds customization and additional fields for the dialog, You can also use this class to write the lookup and validation on the report dialog.
UI Builder Class scenarios used are:
  • Group the dialog fields
  • Override the dialog field events
  • For adding customized lookup dialog field
  • To bind the dialog fields with contract parameters
  • For changing layouts in dialog
  • Adding more custom controls in the dialog
d365technext: Interfaces & Abstract Class Blog bot DAX Blogs 0 09.09.2021 22:13
stoneridgesoftware: Dynamics 365 Unified Interface Provides Consistent User Experience Blog bot DAX Blogs 0 14.09.2018 03:26
d365technext: Class Extension D365FO Blog bot DAX Blogs 0 08.08.2018 14:11
Solutions Monkey: Microsoft Dynamics AX 2012 EP user interface enhancements Blog bot DAX Blogs 0 13.09.2011 10:11
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
Часовой пояс GMT +3, время: 06:46.
