#1 |
dynamicsaxinsight: D365: Send email in X++ using email templates
Источник: https://dynamicsaxinsight.wordpress....ail-templates/
============== Product: Dynamics 365 for Finance and Operations Purpose: The purpose of this document is to demonstrate how we can send emails in X++ using built-in email templates. For demonstration purposes we’ll be using standard email template CnfmOrder. This email template is used to send email to customer when a sales order is confirmed. Business requirement: Automate sending email to customer’s contact when a sales order is confirmed. Prerequisites: Email parameters must be configured. Development: You can find built-in email templates in the system under: Organization administration > Setup > Email templates Note that we have keyed in the sender email field as it will be used in the code as the “Sender”. ![]() You can use the following code to automatically send email using X++. The given code also handles inserting placeholder values in the email template. It uses salesId variable which is a global class member and is provided by the caller class. public void generateEmail(){ // Tokens for email template replacement #define.SalesIdToken('salesid') #define.CustNameToken('customername') #define.DeliveryAddress('deliveryaddress') #define.CustomerAddress('customeraddress') #define.ShipDate('shipdate') #define.ModeOfDelivery('modeofdelivery') #define.Charges('charges') #define.Discount('discount') #define.Tax('tax') #define.Total('total') #define.LineProductName('lineproductname') #define.LineProductDesc('lineproductdescription') #define.LinePrice('lineprice') #define.LineQuantity('linequantity') #define.LineNetAmount('linenetamount') SalesTable salesTable; SalesLine salesLine; CustTable custTable; ContactPerson contactPerson; SalesTotals salesTotals; SysEmailId emailId; Map templateTokens; str emailSenderName; str emailSenderAddr; str emailSubject; str emailBody; str emailToAddress; salesTable = SalesTable::find(salesId); salesLine = SalesLine::find(salesTable.SalesId); custTable = CustTable::find(salesTable.CustAccount); contactPerson = ContactPerson::find(salesTable.SixCustContactPersonId); salesTotals = SalesTotals::construct(salesTable); emailToAddress = contactPerson.email(); emailId = salesTable.SixSysEmailId; templateTokens = new Map(Types::String, Types::String); templateTokens.insert(#SalesIdToken, salesTable.SalesId); templateTokens.insert(#CustNameToken, custTable.name()); templateTokens.insert(#DeliveryAddress, salesTable.deliveryAddress().Address); templateTokens.insert(#CustomerAddress, custTable.address()); templateTokens.insert(#ShipDate, strFmt("%1", salesTable.ShippingDateRequested)); templateTokens.insert(#ModeOfDelivery, strFmt("%1", salesTable.DlvMode)); templateTokens.insert(#Charges, strFmt("", salesTotals.totalMarkup())); templateTokens.insert(#Discount, strFmt("", salesTotals.totalEndDisc())); templateTokens.insert(#Tax, strFmt("", salesTotals.totalTaxAmount())); templateTokens.insert(#Total, strFmt("", salesTotals.totalAmount())); templateTokens.insert(#LineProductName, salesLine.itemName()); templateTokens.insert(#LineProductDesc, salesLine.itemLineDisc()); templateTokens.insert(#LinePrice, strFmt("%1", salesLine.SalesPrice)); templateTokens.insert(#LineQuantity, strFmt("%1", salesLine.SalesQty)); templateTokens.insert(#LineNetAmount, strFmt("%1", salesLine.LineAmount)); if (emailId) { [emailSubject, emailBody, emailSenderAddr, emailSenderName] = SixCustVendEmailController::getEmailTemplate(emailId, custTable.languageId()); } var messageBuilder = new SysMailerMessageBuilder(); messageBuilder.addTo(emailToAddress) .setSubject(emailSubject) .setBody(SysEmailMessage::stringExpand( emailBody, SysEmailTable::htmlEncodeParameters(templateTokens))); if (emailSenderAddr) { messageBuilder.setFrom(emailSenderAddr, emailSenderName); SysMailerFactory::getNonInteractiveMailer().sendNonInteractive(messageBuilder.getMessage()); }}The generateEmail() method calls the following method to get the email template: protected static container getEmailTemplate(SysEmailId _emailId, LanguageId _languageId){ var messageTable = SysEmailMessageTable::find(_emailId, _languageId); var emailTable = SysEmailTable::find(_emailId); if (!messageTable && emailTable) { // Try to find the email message using the default language from the email parameters messageTable = SysEmailMessageTable::find(_emailId, emailTable.DefaultLanguage); } if (messageTable) { return [messageTable.Subject, messageTable.Mail, emailTable.SenderAddr, emailTable.SenderName]; } else { warning("@SYS135886"); // Let the user know we didn't find a template return ['', '', emailTable.SenderAddr, emailTable.SenderName]; }}Once triggered, the code sends out the email through the configured SMTP server and can be found in the inbox: ![]() Источник: https://dynamicsaxinsight.wordpress....ail-templates/
