Старый 09.04.2018, 20:12   #1
mfp: Container to bindata, and back again
Источник: https://blogs.msdn.microsoft.com/mfp...nd-back-again/
I was recently engaged in a bug where the size of container caused problems. The solution we arrived at was to implement compression of the container. The solution is trivial; but the APIs to get there took me a while to discover, and as I couldn't find any other post on this, I'm sharing it....
sertandev: Using base64 encoding and decoding for file transfer in AX 2012 Blog bot DAX Blogs 0 20.03.2018 13:11
sertandev: Using base64 encoding and decoding for file transfer in AX 2012 Blog bot DAX Blogs 0 28.08.2017 19:11
Tayfun Sertan Yaman: Using base64 encoding and decoding for file transfer in AX 2012 Blog bot DAX Blogs 0 28.08.2017 13:11
Часовой пояс GMT +3, время: 17:32.
