Старый 27.03.2018, 09:11   #1
25,643 / 848 (80) +++++++
crmtipoftheday: Tip #1094: It is Time to Go with the Flow
Источник: https://crmtipoftheday.com/1094/it-i...with-the-flow/
Microsoft is making lots of noise of late about the soon to be released Spring Release. One of the key takeaways from those announcements is that PowerApps and Flow are a key element of the future for app development in Dynamics (Canvas Apps, as they call them). If you still think PowerApps and Flow are the playthings of non-developers to do things poorly until a ‘real’ developer arrives, you are holding yourself back from a world of opportunity and it is time to embrace the new.
Of course, at TOTD we have encouraged you to embrace PowerApps and Flow before but here I will drill down into how Flow works, especially in regards to Dynamics 365.
First of all, you can go to flow.microsoft.com and sign up for a free trial account. Once you have done this you can look at the sample templates but there is not a huge amount for Dynamics 365 so I say jump straight in and build your own. You will need a Trigger (similar to the triggers used to run workflows in Dynamics 365) and, once triggered, you will need the Flow to do something via Actions (just like steps in a workflow).
The triggers we have are at the record level and are:
  • OnCreate
  • OnDelete
  • OnUpdate
While we can make all sorts of apps do something via an Action, for Dynamics 365, we can:
  • Create a record
  • Delete a record
  • Retrieve a record
  • Retrieve multiple records
  • Update a record
We can also run Flows on demand via the mobile Flow app and, unlike workflows, we can schedule Flows to run regularly at a specific time. There really is a lot of power here waiting to be unleashed.
If you are familiar with creating workflows, none of this should look too difficult and I assure you making the leap to Flows will not be a large one.
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
axaptapedia: Current Time Blog bot DAX Blogs 1 29.11.2010 22:11
Часовой пояс GMT +3, время: 02:05.
