Старый 06.04.2017, 09:11   #1
palleagermark: Resolve dll references for a project generated from a template
Источник: http://www.agermark.com/2017/04/reso...r-project.html
When you create a new project from a template, for example a new Best Practice Rules project, you might get a bunch of references that aren't resolved:
To resolve these you can individually point each reference to the correct dll, or you can take the following faster approach.
In Solution Explorer, right-click your project node and click Properties. The Project Designer appears:
Select the Reference Paths page. In the Folder field, type the path of the folder that contains the items you want to reference, and then click the Add Folder button:
The path for most D365fO dll's is J:\AosService\PackagesLocalDirectory\Bin\
Click Save to save the setting and then close the dialog:
And ... voilà:
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 04.06.2010 13:21
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 5.0 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:51
Часовой пояс GMT +3, время: 03:23.
