Старый 05.10.2016, 09:11   #1
organicax: Session date selection in AX7
Источник: https://organicax.com/2016/10/04/ses...ection-in-ax7/
The concept of the session date has been a handy capability in AX for many version. It gives you the ability if you are for exampling entering a lot of journal entries to set the date if you want them to be put through on a specific date which isn’t the actual date. Essentially helping with defaulting the date to avoid you having to re-set it.
Here is a quick overview.
AX7 Build 7.0.4230.16130
Cheers
Lachlan
Filed under: User tips
organicax: New released item in AX7 Blog bot DAX Blogs 0 01.10.2016 04:15
organicax: Enabling an employee for MES, Shop Floor in AX7 Blog bot DAX Blogs 0 28.09.2016 22:15
organicax: MES terminal setup in AX7 Blog bot DAX Blogs 0 28.09.2016 22:15
organicax: Receipt date is not valid on customer calendar Blog bot DAX Blogs 0 07.04.2016 20:13
Часовой пояс GMT +3, время: 12:26.
