Старый 28.09.2016, 09:11   #1
organicax: MES terminal setup – barcode scanner
Источник: https://organicax.com/2016/09/27/mes...rcode-scanner/
If you are looking at using the manufacturing execution screens you might want to consider how the users are going to enter data. One option is to be able to scan a barcode to save them typing. This will mean some planning so that they have a document or scan sheet that they can scan to register the data.
There is a parameter on the terminal setup that you might want to investigate called barcode scanner. If you enable this then you will get an additional field that the user can scan into to pick activities for example.
Here is a quick overview.
AX2012 R3 CU11.
Cheers
Lachlan
Filed under: Production control
organicax: MES terminal – touch screen Blog bot DAX Blogs 0 28.09.2016 09:11
organicax: WMS Packing compile of setup posts. Blog bot DAX Blogs 0 26.07.2016 16:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
emeadaxsupport: AX for Retail: Size Barcode setup and creation with number sequence Blog bot DAX Blogs 0 12.02.2015 01:12
Часовой пояс GMT +3, время: 14:28.
