Старый 05.09.2014, 19:39   #1
If you found this page you might have seen this error when trying to copy 1 or more elements in Visual Studio when designing a Report: “Report Builder was unable to paste successfully
This issue is that 1 of the selected textboxes you are trying to copy has custom code in it, and then you cannot copy the textbox(es).
I.e. you cannot copy a textbox with this custom code: “Code.MyCustomeCode()
Well actually it is not an issue it is bug, which have existed many years now and Microsoft promises to fix the issue in a future version, see here and please vote:
https://connect.microsoft.com/SQLSer...r2-sp2-upgrade
Well future version is a bit a tricky dear Microsoft since nothing has happen since SQL Server 2008 R2, see my blog here: http://mibuso.com/blogs/clausl/2014/...namics-nav-v2/
So let me give you 2 workarounds. The obvious one, but hard and then the easy one.
Option 1, obvious one, but also hard if you have many textboxes with custom code:
1.Open the Expression and copy the custom code in the expression
2. Close the Expression
3. Create new textbox
4. Open Expression, and paste the custom code
5. Now set font, padding and size just like the other textbox
Option 2, the easy one:
1. Open the textbox with custom code
2. Now add a comment after the custom code.
I.e. “Code.MyCustomeCode() ‘This is my custom code’
3. Close the Expression
4. And copy the textbox
Don’t ask me why this is working, but now you have a good reason to comment your code. If you´are designing an ISV solutions or if you are the NAV team and have custom code in any of your reports be kind to add a comment in the expression so developers after you can copy your text boxes.
/Thanks, Claus Lundstrøm, MVP for Microsoft Dynamics NAV
Читать дальше
Часовой пояс GMT +3, время: 02:27.
