Старый 23.07.2015, 00:12   #1
emeadaxsupport: “The clocks on the client and server machines are skewed” error resulting in reports showing label IDs instead of text
Источник: http://blogs.msdn.com/b/axsupport/ar...d-of-text.aspx
Working with a DEMO VM, I ran into a scenario where Microsoft SQL Server Reporting Services (SSRS) reports were showing label IDs instead of text. Since everything was on the same box I opened Event Viewer and looked at Windows Logs > Application to see any related errors. The error that got my attention was
AXRDCE The AXRDCE extension caught an unexpected exception for report CustBasedata.Report.
The error message was:
A call to the Microsoft Dynamics AX SRSFrameworkService service failed. The clocks on the client and server machines are skewed.
Doing a quick search online showed that there was an issue with time synchronization.
To resolve I ran the following command [net time /set /yes] and restarted SQL Server Reporting Services service.
Reference: NET TIME and w32time
emeadaxsupport: AX 2012 reports fail to deploy on a server hosting multiple SQL Server Reporting Server instances Blog bot DAX Blogs 0 15.06.2012 11:11
emeadaxsupport: How label flushing works under the hood Blog bot DAX Blogs 0 17.08.2010 16:05
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 02:01.
