#1 |
emeadaxsupport: AX 2012, a TableMap object turns to be a Table
Источник: http://blogs.msdn.com/b/axsupport/ar...e-a-table.aspx
============== Issue description: We have seen some scenarios while deploying Models/ModelStore among multi environments, that a TableMap object turns to be a Table. Cause: Unknown, no consistent repro pattern has been spotted Resolution suggestion: We take e.g. that the affected object is the 'CustVendInvoiceTrans' table map. Run the following SQL script in order to correct the object type: -- Assumption: Script works against dev model store -- Assumption: Clean baseline model store is named: axdbdev_model_id_baseline (can be replaced by own naming) -- Check existence affect object in dev environment SELECT m.ElementType, m.Name, m.AxId, md.LayerId, manifest.DisplayName, md.Properties as Metadata FROM [dbo].ModelElement AS m INNER JOIN [dbo].ModelElementData AS md ON m.ElementHandle = md.ElementHandle INNER JOIN [dbo].ModelManifest AS manifest ON md.ModelId = manifest.ModelId AND m.ElementType = 44 AND m.Name = 'CustVendInvoiceTrans' -- Check existence affect object in baseline environment SELECT m.ElementType, m.Name, m.AxId, md.LayerId, manifest.DisplayName, md.Properties as Metadata FROM axdbdev_model_id_baseline.[dbo].ModelElement AS m INNER JOIN axdbdev_model_id_baseline.[dbo].ModelElementData AS md ON m.ElementHandle = md.ElementHandle INNER JOIN axdbdev_model_id_baseline.[dbo].ModelManifest AS manifest ON md.ModelId = manifest.ModelId AND m.ElementType = 44 AND m.Name = 'CustVendInvoiceTrans' -- Replace corrupted metadata on dev environment from baseline environment Update md Set md.Properties = md_base.Properties FROM [dbo].ModelElement AS m INNER JOIN [dbo].ModelElementData AS md ON m.ElementHandle = md.ElementHandle INNER JOIN axdbdev_model_id_baseline.[dbo].ModelElement AS m_base ON m.ElementType = m_base.ElementType AND m.Name = m_base.Name INNER JOIN axdbdev_model_id_baseline.[dbo].ModelElementData AS md_base ON m_base.ElementHandle = md_base.ElementHandle AND m_base.ElementType = 44 AND m_base.Name = 'CustVendInvoiceTrans' AND md_base.LayerId = 0 Источник: http://blogs.msdn.com/b/axsupport/ar...e-a-table.aspx
