Старый 09.07.2011, 05:58   #1
Dynamics AX Sustained Engineering: NF-e Process fails with XML schema error 215 due to missing namespace
Источник: http://blogs.technet.com/b/dynamicsa...namespace.aspx
Problem:
Resolution:
Load the attached Microsoft.Dynamics.AX.NFe.dll file and register the .dll. The make the following code changes.
\Classes\EFDocMsgTransport_WebServiceV4_BR\createBinding
System.ServiceModel.Channels.TextMessageEncodingBindingElement messageEncodingBinding;
To:
Microsoft.Dynamics.AX.NFe.CustomTextMessageBindingElement customTextMessageBindingElement;
messageEncodingBinding =
//BP Deviation Documented
new System.ServiceModel.Channels.TextMessageEncodingBindingElement(
System.ServiceModel.Channels.MessageVersion::get_Soap12(),
System.Text.Encoding::get_UTF8());
To:
CustomTextMessageBindingElement = new Microsoft.Dynamics.AX.NFe.CustomTextMessageBindingElement("utf-8",
"application/soap+xml",
System.ServiceModel.Channels.MessageVersion::get_Soap12());
bindingElementArray.SetValue(messageEncodingBinding, 0);
To:
bindingElementArray.SetValue(CustomTextMessageBindingElement, 0);
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 SP2 with Dynamics AX Blog bot DAX Blogs 0 18.05.2011 05:16
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 09:38.
