Старый 29.06.2010, 19:05   #1
palleagermark: When sysMailer.quickSend isn't sending any mails
Источник: http://palleagermark.blogspot.com/20...t-sending.html
After rather many hours of debugging and hairpulling, I have figured out that you in order to send mails with sysMailer.quickSend, must have View rights to the security key Adminstration / Daily. You don't need to have access to any of the subnodes however.
The cause is that sysMailer.quickSend in order to find the password to the SMTP server, calls SysEmailSMTPPassword::currentAOSInstance, which again makes a select statement to the SysServerSession table.
The SysServerSessionsTable must somehow be linked to the above mentioned security key, because without access to this, AX simply exits the metod on that select statement, just as if it had hit a Return statement - and no errors or other hints about the mail not being sent are displayed.
Не создается экземпляр SysMailer в RunBaseBatch pvito DAX: Программирование 3 21.10.2011 15:30
SysMailer, доступ? propeller DAX: Программирование 6 30.05.2011 14:42
palleagermark: Book review: "Microsoft Dynamics AX 2009 Programming: Getting Started" Blog bot DAX Blogs 0 15.01.2010 02:09
palleagermark: Setting up E-mail parameters on the AX 2009 VPC July 2008 image Blog bot DAX Blogs 0 31.10.2008 10:05
Microsoft Dynamics AX AIF: Sending Outbound Documents Automatically Blog bot DAX Blogs 0 31.03.2008 11:05
Часовой пояс GMT +3, время: 12:54.
