Старый 13.12.2007, 22:30   #1
axaptapedia: Array (Foundation class)
Источник: http://www.axaptapedia.com/Array_%28Foundation_class%29
Summary: Added tips
'''Array (Foundation class)''' function the same way as ordinary [[array]]s, the main difference being thata [[table buffer]]s and [[object]]s can be used as contents.
The array is created with a [[Types|type]] that defines what contents the array contains. It can not use Types::Anytype!
==Example==
array a = new array(Types::string);
a.value(1, "First");
a.value(2, "Second");
a.value(3, "Third");
print a.lastIndex();
print a.toString();
pause;
==Tips==
When inserting the array is dynamicly expanded. If you just want to add an element to the end of the array it is possible to use:
a.value(a.lastIndex()+1, "element");
If a [[container]] is needed use the pack method:
c = a.pack();
==Methods==
* definitionString
* exists
* lastIndex
* pack
* toString
* typeId
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
axaptapedia: Image class Blog bot DAX Blogs 0 22.07.2008 15:05
axaptapedia: Set (Foundation class) Blog bot DAX Blogs 0 24.04.2008 20:19
Часовой пояс GMT +3, время: 13:05.
