Старый 20.07.2007, 18:00   #1
axaptapedia: WMI
Источник: http://www.axaptapedia.com/WMI
Summary: New page: == Using WMI in Axapta 3.xxx == === List of all processes with creation time and owner === static void Test_WMIListProcesses(Args _args) { COM WMIService = COM::getObjectEx(@"w...
COM WMIService = COM::getObjectEx(@"winmgmts:{impersonationLevel=impersonate}!\.\root\cimv2");
COM processes = WMIService.ExecQuery("Select * from Win32_Process");// where Name='excel.exe'");
COMVariant userName = new COMVariant(COMVariantInOut::Out, COMVariantType::VT_BSTR);
COMVariant userDomain = new COMVariant(COMVariantInOut::Out, COMVariantType::VT_BSTR);
COMEnum2Object i = new COMEnum2Object(processes);
COM process = i.getFirst();
str time;
str reformatTime(str _WMITimeStamp)
str yy = subStr(_WMITimeStamp, 1, 4);
str mm = subStr(_WMITimeStamp, 5, 2);
str dd = subStr(_WMITimeStamp, 7, 2);
str hh = subStr(_WMITimeStamp, 9, 2);
str m = subStr(_WMITimeStamp, 11, 2);
return dd+'.'+mm+'.'+yy+' '+ hh +':' + m;
while(process)
info(process.Name());
if (process.Name()!='System Idle Process'
process.Name()!='System'
time = process.CreationDate();
info(reformatTime(time));
process.GetOwner(userName, userDomain);
info( userName.bStr() + " | " + userDomain.bStr());
process = i.getNext();
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axaptapedia: Tutorial Form Dynalink Blog bot DAX Blogs 0 22.08.2007 23:00
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 13:36.
