Старый 29.10.2021, 10:11   #1
shashidotnet: Visual studio – Copy all from Find Symbol Results
Источник: https://shashidotnet.wordpress.com/2...ymbol-results/
can-i-copy-multiple-rows-from-the-visual-studio-find-symbol-results-window
https://stackoverflow.com/questions/...results-window
Sometimes it is probably useful to copy all the data from the Symbol results window in Visual studio. Either to process it manually or to run some analysis on it (Or whatever reason you fancy). Unfortunately Visual studio only allows you to copy one result at a time from that window which doesnt make it very friendly. I had over 600 results
Bring in AutoHotKey ! This is an extremely powerful scripting language. It runs off keyboard shortcuts, so you can run this from where your cursor is pointed at.
For my scenario, i managed to make it run with Ctrl + j and it goes through all the lines so quickly that VS doesnt skip to the source reference file.
Once installed, run it in the same context as Visual studio i.e. is VS is running as an administrator then run the script as an administrator as well (So that VS doesnt capture the hotkeys and keep it to itself)
https://github.com/shashisadasivan/M...mbolResult.ahk
View this post on Instagram
Bugsy's Blog: Visual Studio Code Updates for Java Developers: Rename, Logpoints, TestNG and More Blog bot NAV: Blogs 0 19.12.2018 04:40
Bugsy's Blog: New Azure DevOps Work Item Experience in Visual Studio 2019 Blog bot NAV: Blogs 0 19.12.2018 04:40
Mark Brummel: Invoking Azure Functions from AL in Visual Studio Code Blog bot NAV: Blogs 0 29.08.2017 19:11
clauslblog: Never close down Visual Studio when designing RDLC Reports Blog bot NAV: Blogs 0 15.05.2016 18:12
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 02:22.
