Старый 11.09.2021, 15:19   #1
d365technext: intermediate language CIL IL D365FO
Источник: https://d365technext.blogspot.com/20...eLanguage.html
What is an intermediate language?
Intermediate language (IL) is an object-oriented programming language designed to be used by compilers for the .NET Framework before static or dynamic compilation to machine code. The IL is used by the .NET Framework to generate machine-independent code as the output of the compilation of the source code written in any .NET programming language.
IL is a stack-based assembly language that gets converted to bytecode during the execution of a virtual machine. It is defined by the common language infrastructure (CLI) specification. As IL is used for the automatic generation of compiled code, there is no need to learn its syntax.
This term is also known as Microsoft intermediate language (MSIL) or common intermediate language (CIL).
d365technext: D365FO Interview Question Blog bot DAX Blogs 2 10.09.2021 10:52
d365technext: Current language D365FO Blog bot DAX Blogs 0 12.08.2018 17:18
german_nav_developer: Dynamics NAV 2013 R2 multi-tenancy – Viele Mieterinnen ohne Stress und Neid Blog bot Dynamics CRM: Blogs 0 30.12.2013 19:00
Dynamics AXBR: AX2012 – Common Intermediate Language (CIL) – (Parte I) Blog bot DAX Blogs 0 04.04.2013 09:11
german_nav_developer: Codepage und Multilinguale Dynamics NAV Installationen Blog bot Dynamics CRM: Blogs 0 05.06.2011 15:51
Часовой пояс GMT +3, время: 22:31.
